Steering clutch problem on 350B dozer
I replaced steering clutch with new fiber and steel disks, throw out bearing, and pressure plate. Made adjustments to steering lever and brake according to manual. Now it slips, could I have missed something?
Re: Steering clutch problem on 350B dozer
Had to. Either not enough plates or didn't torque down pressure plate. Even if you didn't use the JD7 gauge it shouldn't slip unless the pressure plate inner springs are broken.
Users browsing this forum: No registered users and 114 guests
