What PSI are 450 hydraulic hoses for loader ?
pearljam724
Post by pearljam724 » Thu Dec 29, 2022 12:13 pm
My hoses are too old to identify. Anyone know PSI for loader hoses ?
B Town
Re: What PSI are 450 hydraulic hoses for loader ?
Post by B Town » Thu Dec 29, 2022 2:47 pm
I use two wire hydraulic hose. I think max operating pressure of 6,000. I am pretty sure the two wire hose is what was used by Deere for the loader application.
pearljam724
Post by pearljam724 » Thu Dec 29, 2022 5:15 pm
I found some 2-wire locally and they are only 3,100 PSI. Will that be ok ?
B Town
Post by B Town » Thu Dec 29, 2022 5:48 pm
Should be fine. Pressure relief is usually around 2,250.
original possum
Post by original possum » Fri Dec 30, 2022 9:47 am
I believe the relief valve is only active while you are using a function and the lines may see a higher pressure when you are not using that function. Think running into an obstacle.
B Town
Post by B Town » Fri Dec 30, 2022 12:44 pm
Correct, there is a difference in nominal operating pressure and burst pressure.
Post by Jim B » Fri Dec 30, 2022 2:56 pm
Talk to the supplier for all the info about the hose. Your local 3100 psi hose is normally showing the working pressure on the casing. Burst pressure is generally about 4 times the working pressure, so a 3100 psi working pressure hose would have a bursting pressure in the 12,000 to 13,000 psi range. the burst pressure rating covers surges. It will be fine.
Users browsing this forum: No registered users and 137 guests
