Lavoy, is there anywhere a guy can get a final drive seal kit any cheaper? I need the seal kit for the spindle, the machined surface oil seals with the rubber outer and inner seal. It appears to be part number AT36097 for the kit. While digging my basement it started to leak a little gear oil and now it is starting to pour out as soon as I fill it up. I still plan to get another set of steering clutches off of you, just haven't had time to work on the other machine yet. Oh yeah, does a guy have to pull the complete final to replace those seals? I would assume so, just checking to see if I could get away with a little time saving. I have a feeling that getting the spindle through the bull gear without messing up the new seal would be a miricle in its self. THANKS.
Shannon
JD350 spindle seals
Users browsing this forum: No registered users and 99 guests
