93A Repair Kit
93A Repair Kit
I was going to rebuild the outrigger cylinders on my 93A but I see uncle Deere wants $141 for a rebuild kit each?!?! that seems obscene. What am I missing that they can get away charging that for the kit. Is there some special material or component?
Lavoy, do you carry these? Any where else to find them? I figured rebuilding a cylinder would cost $20-$30 per cylinder.
1970 350 with a 93A backhoe attachment
I can't speak to this specific kit, but Deere's prices can be substantially higher than other aftermarket sources for the identical part. It's the price for being "green"
Re: 93A Repair Kit
Suggest trying brokentractor.com, although I have not checked for your specific rebuild kits myself. I got rebuild kits for the blade cylinders for my 450C. Brokentractor charged $45 per kit, JD charges $170 -- and they were embarrassed to tell me that high price (they probably don't sell a lot at that price).bonker81 wrote:I was going to rebuild the outrigger cylinders on my 93A but I see uncle Deere wants $141 for a rebuild kit each?!?! that seems obscene. What am I missing that they can get away charging that for the kit. Is there some special material or component?
Steve (450C rebuild now complete, and I'm pushin' down trees!)
JD 450C, Serial No. 316559T
Kubota L3400 top-n-tilt
I bought seals for my JD400 backhoe here:
http://www.epm.com/john_deere450.htm
Good price, good service
Nils
Nils
JD400A Backhoe
If Lavoy can't find you parts I use Hercules BullDog for parts here is a number for you !-800-777-5617 I have the numbers for you code-PV8 rod size1 3/4 bore size3 1/2 and Deeres number is JD-RE1875419 the1995 price is 45 bucks I use these seals on all my equipment and they are as good or better than origional It says all 93-93A-9250 and9550have the same part#Digitup.
If lavoy don't have the. I use crawer Heaven , nice dude to talk with. http://www.crawlerheaven.com/contactus.htm
Users browsing this forum: No registered users and 91 guests
