350 dozer reverser leak
I am hoping that someone with some experiecnce with 350 dozers can shine a light on a question that I have. I just purchaced a 1969-70 model 350 dozer from a neighbor that had her husband pass away. It had a problem that developed when he was out piling brush with the dozer. It developed a severe leak on the left side front corner of the belly pan area. It looks like it may be coming from the reverser area. I understand that the reverser has a couple of hoses and I am suspecting that one of those hoses had a stick run through it. How hard are the hoses to change and does anyone have any tips on how to make the job easier? I am assuming that once I get the belly pan off and get under the dozer it will be apparant where the leak is coming from. Does this sound logical or am I all wet on this problem?
I completely rebuilt an early 350 once and I remember that the oil cooler lines were in two sections with a hose and clamps between the two lines. The newer models eliminated the hoses and use metal to metal connectors and a longer front line.
That is indeed the most likely source of a leak and just replace it with some good hydraulic hose.
To get the pan off, I just used a block of wook and a floor jack. I think the hoses go down the left side in the area of the side frame.
Users browsing this forum: No registered users and 107 guests
