Reverser line leaking
Reverser line running to the front of the radiator rub through leaking bad. Power washed where I could see what is going on just a big pain in the neck. I cut the metal tube with drimmal an slipped a 1/2 rubber power steering hose over the tube clamping it then to the reverser tube. the way I seen it I would have needed to drain the collant an may be take the radiator off to fix it right .
Users browsing this forum: No registered users and 127 guests
