welding
welding
So I picked up this 350B a few weeks ago, been working on her and finally pressure washed the under carriage. I should have done that first!! Found both cross shafts are welded and have recracked to the side frames. So now I have to remove the whole under carriage as a system and lift the crawler off of it then cut it all apart to repair it correctly. Anyone know of some decent used frames and cross shafts? I also need two tensioners, 4 lower rollers, both upper idlers and shafts and two sprockets. was told it was all new 400hrs ago, only the chains are in specs..
I started cutting out the bad welds and rotted pieces to replace all the bad metal and welds.
350BW, 6 way Dozer
'86 Ford 555 backhoe, side-shift 4:1 ext hoe, 4X4
'03 F350 CC, 6.0L, 8', 4X4, Lariat
'03 Honda VTX1800
'01 Honda XR650L
'01 Subaru Outback Wagon "was Grandpa's"
Vintage sleds and a shop full of tools and toys!
'03 Honda VTX1800
'01 Honda XR650L
Users browsing this forum: No registered users and 149 guests
