Lower rollers
Lower rollers
Do you rebuild lower rollers with bearings and seals or just replace the roller as a unit? I notice there is a plug to add lube in the center of the roller what lube goes in them? also what is the fluid for the final drive deere 450d thanks and I do have a book on the way.
For the most part, you can't afford to reuild rollers, cheaper to replace.
