Filter in hydraulic reservoir tank??
I have a 1965 straight 350 gas crawler. The hydaulic pump went out and I replaced it. When I went to drain the tank and replace the filter that is supposed to be in it and I found out that mine has a solid cover on the tank and no filter system for it. The service manual shows a cover with six removable bolts with a gasket and filter element attached. Talked to the previous owner and he said that he replaced the pump last in the early 80"s and as far as he knows it was always like this. Just wondering if anyone else has seen this out there and maybe they just made the first few models like this. The service manual also shows a metal strainer inside by the suction line. I don't know if that is in there either because the fill opening is not that big to get a good look inside.
Early 350s don't always have one. My 68 did not, either. It may have been a 'rough service' option, hence no cover on mine. Mine was a basic machine, no reverser and the outside blade and standard pad width.
The filter may have been an option which eventually wound up as standard. Or, it may not have existed at all until a certain point in production. One would need original sales material to see ifnit was optional or not on the early machines.
There was a lengthy discussion on this topic back on January 12, 2012, i don't know how to bring up sight, but i have 67 350 dozer and a loader I believe is a 68. The dozer has small narrow hydraulic tank with no filter and the loader has the long tank with the filter with the 6 bolts on top. There are pictures of both in this thread. Its on page 21, Thread line #22.
57 420c 86 Ford 4600
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
I have a 1965 machine, outside mount dozer and has no filter either. There is lots of room in the tank side compartment, below the control valves for a filter....good thought. Do the spin on filters work inverted as well as upright? I have to pull my side cover off this spring to fix a slow leak in there...a good time to put in the filter.wfoidaho wrote:Thanks for the info. apparently my 350 doesn't have a filter. It is the narrow tank. Has anyone installed a inline filter on the return supply line?
Cheers
Paul
Right now I have bigger fish to fry; left steering clutch is oil soaked, After I get this work done I'll look at installing a filter on the return side adjacent to the tank. I already have a filter base in my box of "treasures"; it can't be all that difficult to do, just some plumbing work.
I am surprised nobody's done this already as filters are a heck of a lot cheaper than pump rebuilds or replacement.
