frozen/bonded steering clutches.
Brothers, RE: JD 350. Steering clutches wont release. Linkage was also stuck. I got linkage freed up and adjusted. The brakes apply and lug engine properly but steering clutches will not release. Have drove up and down steep hills with levers back , dumped the clutch foward and reverse . Currently have levers tied back and filled steering clutche housings full of kerosene. Any advice?
water would/might work..... kerosene/oil is the worst thing you could put in there...... now you will have to pull it down and replace ALL the clutch fibers and the brake bands ANY oil on them destroys them in short order
Rust is a product of water, not petroleum. No petroleum product cuts the rust like water, but any petroleum product destroys steering clutches. The other issue is as the fiber discs absorb water, they swell just like a sponge, and crush the pressure plate fingers down against the pressure plate frame in most cases. As JT said, tear down and replace is only option, no easy rides when it comes to crawlers.
Ive got it apart. No damage to fiber clutches or brake band. The clutches were so bonded that some of the fiber pulled off and stuck to the metal plates when i pryed them apart. Also noted no fiber plate behind the circlip of center hub. It has been apart before.
Anything i need to know about lubing the linkage and throwout bearing?
If there was that much moisture or water I there, I would be throwing away some parts. Throwout and pilot bearing maybe, definitely fibers, probably the pressure plate. Look really closely at the brake band, if the moisture has been in there long enough, it rusts the brake band lining off of the steel part.
Fix everything while you are in there, then no need to go back in later.
original possum
Yes, good point, I missed that. It must have really crushed the pressure plate fingers down when they put it together. Would almost make you wonder if they ever used the crawler again after assembly? I guess it could have broken the teeth in the disc and relieved enough pressure to work.
assuming it is just like a late 2010 if the snap ring is not between fiber 1 and 2 it would not affect the release only that the hub would be floating outward and would not be in-gauged with the last fiber most likely
I bought it from a mechanic who said steering breaks were out. It's got 1264 hrs, tracks 95%. He just wasn't into it and I got it for 3k. Whoever put it together couldn't have run it. One other note the brake drum has worn 1/8" wear groove yet brake band is full thickness. The brake drum has the most wear of anything on the tractor.
The reverser is on the dash but the key shuts it off so i guess its a 350 straight and a half.
Men, I really enjoy this site. Thanks.
Yeah, that's true, it wouldn't really effect the fingers now that you say that.
