JD 350 Seat Frame
jthornton
- Contact:
JD 350 Seat Frame
Does anyone have a photo of a JD 350 seat frame and some dimensions? From the catalog it looks like some angle and some tubing. Mine is a piece of plywood sitting on some angle with holes in it. I'd like to restore the seat to original condition.
JT
JT
From my parts book. FYI, you can look at the parts book free on line in the John Deere web site. You might know this but just in case I copied it for you.
I could measure it for you next weekend when we get back from Mexico.
backhoe attachment.
backhoe attachment.
jthornton
- Contact:
I have no frame at all, just some angle across the bottom that looks factory and a makeshift bracket that holds the back of the seat.
Edit: I found seat cushions at http://www.brokentractor.com and I think I only need the bottom cushion and some close up photos of the frame and I can fabricate a new frame.
Here is what I have.
JT
JT
The bottom cushion you have looks correct, but if you want a new one, I carry the same brand they do, aw well as a couple others.
That is correct.
Now I can't find the actual dimensions of the cushion, just had it, oh well. How much gap is there between the cushion and the sides?
I did yes, just have not had time to look up the other pieces.
The gap you have sounds about right, the seat frame is small angle iron, so that is about all the gap you would need.
