JD350C Reverser
JD350C Reverser
We have a JD350C with no forward or reverse motion. I suspect it is the reverser and am in the process of doing the pressure tests. My question is what is the most likely thing/part to fail on the reverser? Any info or opitions are welcomed
JD440 IND w/loader and 253 Diesel
If you have pressure or hear a distinct change in tone when shifting from forward to reverse in neutral then the pump and reverser are probably okay and suspect the splined coupling. If no pressure then suspect the isolator on the flywheel ahead of the reverser. But be advised that running with a blown isolator can be dangerous to the equipment. Either way at least the engine comes out.
Users browsing this forum: No registered users and 114 guests
