350c lift pump
mc_mike
350c lift pump
Post by mc_mike » Sun Aug 17, 2014 6:03 pm
Anyone ever change the mechanical style lift pump to an electric one? I seem to be having bad luck with the mechanical ones, the diaphragm keeps cracking and I fill the crank case with oil. Thinking about putting an electric one in its place. I assume I would just need a low pressure pump? Suggestions?
DrLoch
Post by DrLoch » Mon Aug 18, 2014 7:26 am
Consider looking at this one.
Mr. Gasket#720-12D
Electric Fuel Pump
Diesel
35 GPH
4-7 PSI
Inlet/Outlet: 5/16''
Includes 100 Micron In-Line Filter
450C Track Loader
291457T
pondhogvt
Post by pondhogvt » Tue Aug 19, 2014 8:10 pm
Just checking but if the pump seals on the injector pump shaft are torn or worn,,, that is the usual source of oil pan filling with fuel and will ruin a motor in a hurry.., best of luck Mark.
Users browsing this forum: No registered users and 21 guests
