450C chain replacement
Going to be removing track chain it needs new pins and bushings. wondering if replacement with after market chain is less expensive than having p&b replacement
any input would be appreciated
JIM
JIM
New chain may not be cheaper, but might be awfully close to the cost of new pins and bushings.
450C under carriage parts
Have a broken spring needing replacement new used after market??
JIM
JIM
$275 I dont know what deere gets ....... http://www.ebay.com/itm/New-John-Deere- ... 4aadaa49cb
450c
Hi,, I have acouple used ones for 450C, just not sure how to get them out without getting killed,, give me a day to figure out how to de-compress them... Mark
This thread has a write up I did on my springs.
http://www.jdcrawlers.com/messageboard/ ... highlight=
Might help you both get going.
JD- 450C track loader
Serial #208336T
Serial #208336T
Thanks for the replies found one on eBay 250.00 its on the the way also I have available where I used to work a 50 ton arbor press just have to make the up the rod to hold it together my caps are in pretty bad shape presently soaking in muradic acid will inspect tomorrow track frame is completely dismantled.
Thanks jim
Thanks jim
parts ordered
placed order today for chains sprockets 4 bottom rollers $2231.66 inc shipping spring will arrive Monday purchased 1" gr. 8 threaded rod to hold spring together after its compressed $44.00
Re: parts ordered
Jsal, if you don't mind me asking who did you end up buying your undercarriage parts thru? That pricing seems pretty good. My 420 is currently sitting in the woods overnight with a thrown track desperately needing a 350 undercarriage upgrade....jsal wrote:placed order today for chains sprockets 4 bottom rollers $2231.66 inc shipping spring will arrive Monday purchased 1" gr. 8 threaded rod to hold spring together after its compressed $44.00
- Paul Buhler
Hey Paul, it wasn't too bad getting the track back on about 2 hours worth. Now to deal with a leaking hydraulic cylinder. I think I heard someone say there is no such thing as a cheap crawler! I think Stan Disbrow was on to something....Paul Buhler wrote:Notmeu: Hope you get your machine put together without too much difficulty. PaulMy 420 is currently sitting in the woods overnight with a thrown track
- Paul Buhler
Tom: Yeah, Stan has it right; if it's not money, it's time invested. But when they run, they sure beat a pick and shovel. Good luck with your new challenge. My crawler has its own quirks and challenges which keeps me on my toes.
Users browsing this forum: No registered users and 86 guests
