350B brake drum
350B brake drum
How do you know when the brake drum is worn too much and needs replacing?
JD 350B w/ 4 in1
JD 4520 Compact Utility
JD 1025R Sub Compact
Cat 303.5 Mini Ex with Bushmaster Brush Cutter
Soilmover Dirt Pan
Soilmover Dirt Pan
Unless you have a fairly noticeable groove in it, I wouldn't worry about it. If need be, I can have a set of bands made with thicker lining, and you can turn your drums.
350b brake drum
I measured the depth of wear and it is .035 of wear. Is that to much ?
Bennett
Bennett
JD 350B w/ 4 in1
Soilmover Dirt Pan
Soilmover Dirt Pan
To me, with standard brake bands, I think you should be fine. There should be that much adjustment, although I suppose over the life of the bands, you will lose some hours because you may not be able to tighten them down all the way when worn.
Users browsing this forum: No registered users and 110 guests
