Well apparently I knocked one of belly pans loose on the import JD350. I have bent the pan.
It was the rear one, but I noticed the front appears to be hanging low.
Does anyone know the bolt size for these pans?
I have to block up the crawler and get under it tomorrow. I would like to have the bolts on hand to fix it.
Belly Pan bolts
Bolts are probably 5/8" x 1 1/2" NC Grade 8 and the pan should be in front and rear parts. Flat and lock washers on most and four or more have nuts. The captive square nuts in the side frame (front section) are prone to rust and seizing, then spinning. Be ready to burn off bolts, take off the side frames, and weld in new boxes for new captive nuts if you take off the front section.
- Paul Buhler
JMO. OP has very good suggestions, but I believe that grade 5 bolts should suffice for this application, and they are less expensive. Remove the pan and beat it back into the best shape you can cold or with heat, otherwise you'll be underneath it cursing. Bottle jacks, tapered alignment drifts and prayers help. Good luck. Paul
Users browsing this forum: No registered users and 169 guests
