I have a new set of fiber clutches and metal discs, along with new clutch.
When I adjust the clutch fingers using the tool, I remove the little spring clip from the adjuster bolt and proceed to adjust according to the tech manual. But once adjusted there is not enough room between the bolt head and the jam nut to re-install the spring clip. Are these spring clips really necessary? The clutch fingers are adjusted right and everything else checks out ok.
Bennett
Steering clutch instalation problems
JD 350B w/ 4 in1
JD 4520 Compact Utility
JD 1025R Sub Compact
Cat 303.5 Mini Ex with Bushmaster Brush Cutter
Soilmover Dirt Pan
Soilmover Dirt Pan
Here is an image.
JD 350B w/ 4 in1
Soilmover Dirt Pan
Soilmover Dirt Pan
Throw them away, don't worry about it.
steering clutch
Thanks Lavoy
Bennett
Bennett
JD 350B w/ 4 in1
Soilmover Dirt Pan
Soilmover Dirt Pan
Users browsing this forum: No registered users and 102 guests
