Hi Everyone, New to the board..... I inherited a JD450 from my grandpa and have been chasing everything from steering clutches, loss of transmission pressure, to a bad drive clutch. Finally got all them fixed and ten minutes into using the machine and it threw a rod. put two holes in the block 2-3" in diameter.
I have a jd450 (type T5E3M) (serial number 049379T). I have a couple of questions... need some help...
1. How do I know what motor I have? I'm not certain if it is a 4.202 or a 4.219 There is a plate on the side of the motor just above the oil filter with AR59065 on it and there is also a casting stamp on the block that reads R55011 R55034
2.Someone told me I can use either a 4.202 or 4.219, Is this true? If so what do I have to do to make it work?
Anyone know where to get a good used motor? I'm not trying to spend more on the motor than what my old machine is worth.
Thanks for anyone's input.
Matt
JD450 with blown motor
Have you seen these threads?
http://www.jdcrawlers.com/messageboard/ ... light=4202
450 motor
Matt, we talked motors the other day.. If you send me your e-mail address I can send you some pictures of 4-219 and 4-239 motors for sale thanks..
Mark == pondhogvt@gmail.com 802-279-1888
