Just bought new top rollers for the 350b. Old ones were lubricated with grease. Should I do the same for the new ones? It has the same leather seal with the springs behind it. This looks like a grease seal rather than an oil seal.
On another note, This thing is going to nickle and dime me to death. It seems that I take 2 steps forward and 2.5 back. Just enough to say lets keep going but not enough back to warrant giving up. Just a rant.
Bennett.
350b top rollers
350b top rollers
JD 350B w/ 4 in1
JD 4520 Compact Utility
JD 1025R Sub Compact
Cat 303.5 Mini Ex with Bushmaster Brush Cutter
Soilmover Dirt Pan
Soilmover Dirt Pan
Use gear lube or corn head grease, not regular gun grease.
350b top roller
Thanks Lavoy.
Well what about the new front idlers. Should I use grease since it has a grease week?
Bennett
Bennett
JD 350B w/ 4 in1
Soilmover Dirt Pan
Soilmover Dirt Pan
Corn head grease there as well. And, the bottom rollers too if they have fittings (meaning the newer sealed rollers).
The corn head grease is as close as one can get to the crawler roller lube these days.
Yes, they nickle and dime you unless you really bite the bullet and tear it into little bits and put it back together fixing everything at one time. Also, see my bottom line there.
top roller
You are exactly right. I have been working on this thing for three months. Only supposed to replace the steering clutches. Turned into a complete undercarriage rebuild.
Bennett
Bennett
JD 350B w/ 4 in1
Soilmover Dirt Pan
Soilmover Dirt Pan
Users browsing this forum: No registered users and 139 guests
