Finally all togather!!!
FarmLife
Post by FarmLife » Sun Mar 16, 2008 5:25 pm
Finally got the crawler all togather and took it out for a spin last week and it seems to be running pretty well turns nicely. Waiting on the new wiring harness so we can hook up the generator and not cause a fire :shock:
Here is Me on the right and my older brother (co-owner) just before the voyage out of the garage.
Here is another picture that is a little better quality
1934 GP Beaner
1935 B
1935 AR
1935 AO
1936 B
1936 D
1935 A on skeletons
1937 A w/behlen overdrive
1939 B
1940 B
1941 H
1949 M
1954 40 Standard
1953 60 Regular
1955 70 Std Diesel
1954 80
1946 Lindeman
Phase 1 420
Post by JD440ICD2006 » Sun Mar 16, 2008 5:33 pm
You gotta like that old girl.
Tractor 850
Post by Tractor 850 » Mon Mar 17, 2008 5:53 am
Looking good guys :D
Now to have some fun with it :wink:
Dave
JD440IC Ser#445235 W/ #63 Dozer
Ford 850 Ser#55497 W/Wagner Loader
Ray
Post by Ray » Mon Mar 17, 2008 6:51 am
It's good to see that you've got it running. Hearing it run the first time is always an exciting time.
She should be able to pull good with those nice pads.
I see you were able to sell your loader also. That had to make you happy.
Ray
45 John Deere Lindeman ( modified )
46 FMC Bean Cutler ( flat belt drive )
(2) 48 Bolens Ridemasters ser. #R230, #R1051
37 Shaw Du-All tractor conversion
"R/T" home made tractor
1925/26 Centaur tractor conversion
FarmLife
Post by FarmLife » Mon Mar 17, 2008 8:34 am
Selling the loader paid for the original MC fenders, and hopefully it is going to a good home where it will be used.
We had one problem when the left steering clutches cleaned up from driving around and the pressure plate fingers were tight against the throwout bearing making that side slip. We thought the worst but once we adjusted the throwout bearing off of the fingers a bit she would climb up anything.
1934 GP Beaner
1935 B
1935 AR
1935 AO
1936 B
1936 D
1935 A on skeletons
1939 B
1940 B
1941 H
1949 M
1954 40 Standard
1953 60 Regular
1955 70 Std Diesel
1954 80
1946 Lindeman
Phase 1 420
Users browsing this forum: Google Adsense [Bot] and 159 guests
