440 3-pth
Gavin
440 3-pth
Post by Gavin » Wed May 21, 2008 2:30 pm
1st time to try to use forum. I was looking in parts book and understand little and big transmission ; big is after serial no 448001, small is before. Question Will the touch-o-matic system used on the tractors fit to the crawlers? The holes from the parts book look the same on both systems, except for the load-and-depth control anchor yoke. Is there enough room inside the differential box to just drill a hole in the cover and install the touch-o-matic 3-pth? I would like to add a 3-pth to my 440IC. Thank-you. GM440IC.
Post by Lavoy » Wed May 21, 2008 4:22 pm
There is almost no parts interchangeability between crawler and tractor as far as the 3PT hitch goes. They are two entirely different hitches, and operate quite differently.
