40 C steering clutch pack R&R.
ohmgman
Post by ohmgman » Fri May 30, 2008 9:08 am
Thank you.
Upon closer inspection it would seem I need a few more parts....
I need two of THESE...They screw into the final drive housing and provide the attachment point for the brake rod bellow/seal.
Also I need the four bronze bushings for the steering shafts/levers. No use having sloppy levers...
Also, I could use two of the seals for the final drive shaft.
And...two of the sealing rings for the inner bearing cover.
Is there a ...more "preferred method" of me sending you parts orders?
Post by Lavoy » Fri May 30, 2008 3:00 pm
You can e-mail me, there is an e-mail link at the bottom of any of my posts, or you can call 701-361-1006.
ohmgman
Post by ohmgman » Fri May 30, 2008 3:43 pm
Thank you.
Users browsing this forum: No registered users and 182 guests
