440 icd throw out bearing sleve
My sleve has a large flare on the outside end,whyis this and should I replace it or hammer it straight again?????Jim
- Jimmy in NC
I assume you mean steering clutch? If so, it occurs when the throwout bearing holder gets rusty and pulls the sleeve out and jams it up against the clutch disc drive hub. It will also happen if someone has overtightened the adjusting bolt and crushed the washer enough that the bolt hits the throwout tube and pulls it out.
Straightening it is a waste of time, and as Jimmy said, they are not expensive, around $22 now.
Users browsing this forum: No registered users and 148 guests
