Wanted: AM3520T Housing for 420C
Today as I was cleaning and inventoring all the parts to begin re-assembly I found 2 cracks in the bottom of the brake band/ steering clutch housing. JD part number AM3520T. I think the cracks are fixable but this is becoming a restoration and I think if someone has 1 for sale it may be just as economical as a repair. I would prefer one from the right side so the adjusting hole is facing forward. I will not throw this out as maybe someone out there cuold fix it and then use it. Each crack is where the loop for the brake band rides and where the dowel pin from the final cover rides. Thanks in advance for any help. Eric
430C,62 Blade
1947 Lindeman w/Tool Carrier & Blade
1964 1010C w/ 612 Dozer
Users browsing this forum: No registered users and 132 guests
