440IC Distributor Questions
Roger440IC
Post by Roger440IC » Tue Sep 30, 2008 12:17 am
Hi, the shaft on my D-R 1112571 distributor is so worn that it won't open the points when they go over the small lobe unless I push the shaft in that direction. My parts manual doesn't show a part number for the bushing but the service manual shows a bronze bushing. Does anyone know where I could find one of these and /or what the specs are for it? Also, what is the recommended lubricant and quantity that you should put in the oil reservoir in the base of the distributor? Thanks, Roger
440-IC
420-U
Roger440IC
Post by Roger440IC » Sun Oct 05, 2008 6:27 pm
I haven't been able to locate the parts to rebuild my distributor. Does antone know where I can find a rebuilt or used one? Thanks, Roger
440-IC
420-U
Users browsing this forum: No registered users and 52 guests
