Track pads
Track pads
How much advantage to 14" vs 12"??
Will 40 pads fit a 420? Both 2 bolt and both meas approx 6". I did not meas rail notches. Are grouser pads readily available in very good condition??
Gus
Gus
I'm not sure what good that type of info will do you. No track/pad configuration is best in all ground conditions. A smaller pad and/or shorter track has more PSI at ground contact but less friction surface and can do better on hard dirt, then bigger pads. You gain one way, and lose another. And, comparing flat loader-type pads to high-cleat dozer pads - I suspect flat pads will pull just as much and maybe more when on hard concrete - and of course - dozer pads will greatly out perform flat pads on dirt.Ray III wrote:I was wondering too which has more traction, wider or narrower pad. With tires, fatter tires have less traction, but tires don't have grousers.
Deere rated the 420 and 430 at 4,862 lbs drawbar pull (1st gear). What pads did they use on the test machine?
MC was tested on hard-packed dirt with 16 feet of tracks with 28 cleats that measured 11 3/4" by 1 3/4" high. Crawler had a weight of 4293 lbs. and had a max pull of 4226 lbs.
Terratrac GT30 had 15 feet of tracks with pads measuring 12" by 6 1/2" (no cleat depths given). Crawler weighed 4471 lbs. and had a max pull of 4518 lbs.
Wider pads give better flotation due to greater surface area. The main places you would have an advantage with 14" pads would be in snow and mud. When dealing with a soft medium, the more grouser you have, the more traction you will have. If you are talking dry conditions, and the dirt is harder, you really probably will not notice a difference.
I can vouch for that, considering how many times I have been stuck in sloppy stuff with worn triple bar loader track pads.Lavoy wrote:When dealing with a soft medium, the more grouser you have, the more traction you will have. If you are talking dry conditions, and the dirt is harder, you really probably will not notice a difference.
Thanks for the info, kind of what I figured.
Been thinking of welding grouser bars to the worn 14" snow shoes to make staggered grousers like the snow version originally had, would it give the best of all worlds by maximizing penetration in harder ground while having the flotation of the wide pad? Or should I just keep it simple and make it a full grouser?
