track shoes on 440ic
Crawlerbrad
Post by Crawlerbrad » Mon Jul 06, 2009 8:50 pm
i was looking at my crawler and not knowing how many owners had it and what they did with it, there are different thickness of track shoes and a hand full that are like 2 inches wider then the ones that are to be ono there. so i was wondering where can you get the shoes if i were to replace them. also i was told that it used to run on blacktop and the shoes are smooth with no bars for traction. so again where do you get them and how much do they run. also looking for a roller on the bottom of the crawler. where do you get them and how much do they cost. thanks
Post by Lavoy » Tue Jul 07, 2009 1:06 am
I have a few used bottom rollers left, maybe a couple odd pads.
Post by NNAATZ » Tue Jul 07, 2009 10:20 am
I may have a few odd pads floating around also. Do you need two or four bolt? I will check when i get to the shop tonight.
Crawlerbrad
Post by Crawlerbrad » Wed Jul 08, 2009 12:45 pm
I need the 2 bolt pads. i was just wondering what they would cost. not really high on the list of things that i have to do but was just wanting to get some info. for later if i decide to change them. thanks
Post by Lavoy » Wed Jul 08, 2009 3:28 pm
There are no new pads in two bolt. Deere did sell a 2 bolt/4 bolt replacement pad, looked really stupid, last I knew of, they were $60 each or so.
Post by NNAATZ » Thu Jul 09, 2009 7:16 am
sorry the odd ones that i have are 4 bolt 12" 3 bar semi grousers.
Crawlerbrad
Post by Crawlerbrad » Thu Jul 09, 2009 8:15 pm
ok that is fine i think that will be put on the back burner for a while because i have to work on the brakes and steering clutches first then i may try to find some. thanks guys
ejb17
Post by ejb17 » Fri Jul 10, 2009 5:43 am
I have around 55-60 of the 12 inch 2 bolt pads-snow type. They are pretty nice. When you are ready just look me up if you are interested.
430C,62 Blade
1947 Lindeman w/Tool Carrier & Blade
1964 1010C w/ 612 Dozer
