420C prices
- jdcollector
420C prices
Howdy everyone. I'm new to the Messageboard and looking at purchasing my first crawler. I know of a gentleman who has a 420C phase III crawler that he and his sons started to restore and did not finish. The engine has been sent off and completely gone through, the tracks have new pins and bushings, he has a 5-way blade (?), 3-pt. hitch, and it is a 5 roller. The tractor is completely disassembled and nothing has been sand blasted except for the engine, which is already primed and assembled. He is asking $3,500 for the tractor. I believe that this is a good price but I would like to make sure that it is worth it. Any input is greatly appreciated and thanks for all of the input ahead of time.
Patrick Thomson
440 ICD w/ 831 Loader
420C w/ 62 Blade
420C w/ 62 Blade
- jdcollector
That is what I was thinking but just unsure. I have been looking at prices on-line and in some magazines and they have been about the same for something that was already together and running but not restored... I'm guessing the money in the engine and tracks is worth it
Patrick Thomson
420C w/ 62 Blade
420C w/ 62 Blade
- jdcollector
- jdcollector
- jdcollector
Thank you for all the great information. I believe that I will soon be the owner of my very first crawler. I'm sure that there will be many more post since I will have to put it together without haveing taken it apart. Thanks again for all the help.
Patrick Thomson
420C w/ 62 Blade
420C w/ 62 Blade
- jdcollector
Well, I know that I don't have to try to take it apart but it is going to be fun to try and figure out if it is all there when we do go pick it up. I'm trying to figure out the best way to check it off as it gets loaded. Also, what the best way is to carry it all home on the trailer...
Patrick Thomson
420C w/ 62 Blade
420C w/ 62 Blade
I'll try to list all the major parts so you know if anything significant is missing.
Engine
Bellhousing and tube (about 3' long)
Engine clutch
Engine clutch linkage and shaft to connect to transmission
Clutch and brake pedals
Transmission and shifter
Steering clutch housings (each side)
Steering clutch housing covers and plugs (each side)
Steering clutches, brake bands, linkage, steering levers (each side)
Final drive housings (each side)
Final drive pinion gear, bull gear, axle shaft (each side)
Final drive oil pans (each side)
Track drive sprockets
Side frames (each side)
Footrests (each side)
Fenders (each side)
Crossbars (front/rear)
Trackframes, tracks, rollers, idlers (each side)
Drawbar and crosspiece that it sits on
Seat and seat frame
Instrument panel and wiring
Throttle lever and linkage, start linkage, choke cable
Fuel tank
Starter motor
Generator
Radiator
Front nose, hood, and battery tray/box
Hydraulic lines and valves
Engine
Engine clutch
Fenders (each side)
Seat and seat frame
Fuel tank
Starter motor
Generator
Radiator
- jdcollector
