Track cross reference
ptrachte
Post by ptrachte » Thu Nov 13, 2008 10:42 pm
Hi all,
I've been reading many posts about which undercarriage parts go with which crawler, and a while back, Lavoy did a great summary of it. So being the geek that i am, i tried to make a cross reference that could be used to quickly figure out what parts will work on different rigs. (hopefully)
Here is what I came up with. I tried to be as faithful to Lavoy's original text as possible. I could use all your help in validating this table and sending me corrections.
the way it works is you pick the desired model from the left side, as the "donor", and a model from the top of the table for the recipient. then you look where the two models meet and that should be the "parts in common". Again let me know where i might have got it wrong, and i'll correct it and when its all accurate, we can post it to the site as a reference. On the other hand if its too confusticating, i'll just drop it. :oops:
Paul-1010 crawler/loader
Eric.MacLeod
Post by Eric.MacLeod » Fri Dec 26, 2008 9:26 pm
hello i was wondering were is your chart that you was making? have i missed on here ? thanks ..Eric
ptrachte
Post by ptrachte » Fri Dec 26, 2008 10:42 pm
look at it now. I lost the picture for a bit. sorry.
PT
Eric.MacLeod
Post by Eric.MacLeod » Sat Dec 27, 2008 7:56 pm
thanks ! i thought i would go nuts looking for the chart, i remember seeing it than i couldnt find it. kinda like half the other stuff i set down!! Eric..
pop pop
now it's gone again
Post by pop pop » Sat Sep 12, 2009 12:16 pm
it doesn't show up again... maybe make a link to it
pop pop
Re: now it's gone again
Post by pop pop » Wed Sep 30, 2009 10:47 am
pop pop wrote:it doesn't show up again... maybe make a link to it
still not showing up,
Post by Tigerhaze » Wed Sep 30, 2009 2:51 pm
I think the link to the offsite host has been broken- Ptrachte would have to fix it.
ptrachte
Post by ptrachte » Thu Oct 01, 2009 10:08 am
I have it here, but am not sure how to post it on the message board.
[/img]
Post by Tigerhaze » Mon Oct 05, 2009 10:24 am
Hi Paul-
The best way would be to use a thir-party picture sharing site like photobucket. I have instructions on how to do so within the "Messageboard and Announcements" forum.
ptrachte
Post by ptrachte » Wed Oct 21, 2009 12:18 am
Here is a link i believe will be more permanent. Sorry for the inconvenience and delay.
Paul
http://users.upwardaccess.com/trachte/c ... m3m2_1.htm
Post by Tigerhaze » Wed Oct 21, 2009 9:54 am
Hi Paul-
It is great that you took the initiative to get the table back up for us- no worry about the delay.
One comment you may want to add to the table- while the pin/bushing diameter and links are the same for the 1010s and the early 2010s, the 1010s used fewer overall links on each side than the 2010s.
ptrachte
Post by ptrachte » Sun Oct 25, 2009 2:10 pm
Thanks Tigerhaze, i'll add a footnote, and re-post.
