New member! 450 loader!
JD-thomas
Post by JD-thomas » Thu Dec 10, 2009 10:40 am
I bought this loader about 3 monthes ago to clear some land and have been working it hard ever since. I brought it home to add some cage protection the rear of the ROPS and to add limb risers.
Post by digitup2 » Thu Dec 10, 2009 11:44 pm
When stock those limb risers would have the ability to flex with the roll bar as it is on rubber mounts if you don't put flex in the system you will put big stress on the front rad mount and hard nose cowel .Digitup.
JD-thomas
Thanks for info!
Post by JD-thomas » Fri Dec 11, 2009 5:41 am
So I should add some rubber gromets under nose mount?? Maybe 1/2" thick to give them some flexing ability? Or do you have any suggestions? And which end has the flexing ability the nose end or the cage end. Thanks for the input dont wanna create any machine problems....
John Deere 450A Loader
John Deere 317 Skid steer
Post by digitup2 » Fri Dec 11, 2009 6:01 pm
Some flex in there would be nice .It would be a lot easier on the rad and mounts .Digitup.
JD-thomas
Post by JD-thomas » Fri Dec 11, 2009 6:57 pm
Thanks for the input I will add some rubber bushings and lock-nuts so I can run the bolts snug and not tight.
Thanks again!
Eric.MacLeod
grousers
Post by Eric.MacLeod » Fri Dec 11, 2009 8:53 pm
hello! im no expert but i think that those grousers are a little aggresive for a crawler...
JD-thomas
Post by JD-thomas » Sat Dec 12, 2009 6:49 am
Yeah the guy I bought it from had welded 2- 3/4"round rod on the center groove on each flight. So there are 1 1/2" cleats on them, lets just say u can tell where I drive it in the yard by the sheets of centipede grass peeled up.... But they work..
Post by digitup2 » Sat Dec 12, 2009 4:19 pm
Never too aggressive I have several crawlers with 5 inch build ups on them and at 47 tons each they will paddle a lot of dirt These units can pull at 80,000 to 88000 LBS tractive pull in lose soil .They just have poor street manners and don't do much for the float planks either .That roll bar was made to take the front mount bolts out and flip it back on the ground behind the crawler then take the back bolts out and you can drive away from your roll bar .This way two men can take it off and put it back on ,So make the limb risers to flex and come apart at both ends for that reason if you can.Digitup.
Users browsing this forum: No registered users and 171 guests
