a tiller on a 420
justin, from what i understand is that wheeled tractors share very little in the 3 point with with crawlers. i built mine, have close to 4-450 into it after buying steel, hydraulic parts, lift balls, stablizers, top link, leveler, and pins along with other small misc. items. i had just bought a new aftermarket 3 point that fit an M farmall, to retro fit too my 300 Case for 600 delivered from Tony Carbough Tractors. should be here any time! figured i couldnt make anther for that money. im sure it could be fitted to a crawler also.
I don't really damage any grass with the 420 if I don't make crazy turns. That's with worn down grousers though. If it was a real muddy piece of grass, a crawler will actually do less damage than a wheel tractor.JD440ICD2006 wrote:I would not attempt to bush hog my fields with a crawler, it would ruin the field with tracks.
For some reason, the factory 3 point seems weak. About everyone I have seen is broken and/or has been repaired.
- JD440ICD2006
Yea, the conditons have a lot to do with it. My big field that I cut during grass season is the first thing that you see when you get to the property.
Because of the property lines, I have sharp turns on the corners. My 440 has grousers that would eat some grass and dirt if I turned sharp.
I think I can run faster on a wheeled tractor also. At least, it is more comfortable.
I use a wheel tractor for most mowing, except for old pastures that have sat so long they're sprouting small trees.
When that happens, I use the crawler and a trailing brush hog. I set the blade about 6" high. What is too big pushes out of the ground. What isn't bends under the blade to be whacked by the hog.
I don't like using a wheel tractor in this case as sometimes one can get a small tree that bends and is whacked only to be big and tough enough to push thru a tire.
That's not happening with a crawler!
Otherwise, I'd rather (a) move faster and (b) not tear the ground up on turns.
Later!
Later!
Could you let me know where you purchased the 3 pt? Im interested in trying to put one on my 420CNNAATZ wrote:thought i would mention that i recieved that aftermarket 3 point bout 2 weeks ago. got it on the tractor, it is a simple stout unit and see no reason why it cant be adapted to a crawler for who may be looking, ill try to get pics some time in the future.
1957 420C Loader
Users browsing this forum: No registered users and 328 guests
