My 1010 loader is home!!!!!!
killzoneq2
Post by killzoneq2 » Fri Apr 23, 2010 10:07 am
Well after hours of jacking this thing up with a bottle jack, blocking, spinning, I finally got it free from the 6" of dirt it had sank into over the years. Towed it home down the road less than a mile... Brakes work, left steering clutch works right one doesnt. This thing is complete with original service manual and all receipts. In 1983 it had all new sleeves pistons and bearings. I fig if I cant get it running, I will be parting it out. I will be in touch will all as my venture starts. Serial number and model tag is still on the machine.. SN is 1073, Model # is 810-82. Can anyone supply me with any information on these numbers????
Averagy guy with a passion to turn heavy wrenches, my favorite is the sparkler wrench. It always gets those stuck bolts...Other job Mobile Sandblasting Company.
killzoneq2
Need a Reverser cable. Where can I get one?
Post by killzoneq2 » Fri Apr 30, 2010 3:42 pm
I got it running last night!!!! it ran great. Changing the oil, hyd hoses and lines. I need a reverser cable.. Anyone know where I can get one?
Re: My 1010 loader is home!!!!!!
Post by Tigerhaze » Fri Apr 30, 2010 4:14 pm
killzoneq2 wrote: Serial number and model tag is still on the machine.. SN is 1073, Model # is 810-82. Can anyone supply me with any information on these numbers????
I belive the SN and Model number tag you found is for the loader assembly, not the machine. Did you find this tag on the upper right side of the dash area? if so, then it is likely for the loader assembly.
The machine serial number should be a five digit number. The tag, if like my 2010, should be on the operator's right side of the engine block for early SN machines or on the bellhousing for later SN machines.
killzoneq2
Post by killzoneq2 » Sat May 01, 2010 10:04 am
You are right on that loader SN.. Still am looking for the tractor SN
Users browsing this forum: Google [Bot] and 174 guests
