350 Cracked Block
cdunn
350 Cracked Block
Post by cdunn » Sat May 08, 2010 1:37 pm
After completely disassembling my 350 engine (straight) for overhaul, I find that the block is cracked on either side of number two cylinder, from the top all the way down to where it opens into the crankcase. The block is very thin in these two areas. I discovered this after removing the sleeves and pressure washing the inside. Nothing to do but look for another block I guess. Any comments or incouragement appreciated. Lavoy, you wouldn't happen to have one laying around at a good price, would you?
57 420c 86 Ford 4600
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
cdunn
Post by cdunn » Sat May 08, 2010 2:48 pm
After looking again, the crack stops just past where the sleeve seats in the block and does not extend into the main bearing journals. They are hairline cracks barely visible. Would some sort of stop leak work? Man, I'm desperate, don't have a lot of money and its too good of a tractor to salvage or part out.
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
Post by Lavoy » Sat May 08, 2010 3:19 pm
I don't have any blocks, sorry. There are many different block sealers out there, might be woth a try.
cdunn
Post by cdunn » Sun May 09, 2010 10:45 am
The Lord looks out especially, for poor folks and the foolish. Found a donor machine local, with a running engine at a price no one could complain about.
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
Users browsing this forum: No registered users and 275 guests
