![Image](http://i88.photobucket.com/albums/k174/Downeasta/John%20Deere/th_IMG_0255.jpg)
Wiring Diagram
- Willyr
Wiring Diagram
former owner of a 1956 420c
- Willyr
I have seen othere wiring diagrams online, yet my dash doesnt have a cigarette lighter or a hour meter. Stock?
- JD440ICD2006
The optional lighter went in the top right hole, and an optional key switch (on/off) went in the top left hole.
You can purchase both and install them. You can also knock out the tach hole, purchase a tach and locate a tach cable assembly.
Those, along with the screw out fuse would complete your dash. This assumes the original type of rotary switch is in there. I have seen a few mods to this switch.
- Willyr
Uhhh, let me try to clarify. The wiring diagram that I have seen online in pdf form showed for accessories that were not supplied for my tractor. The above wiring diagram shows stock as my tractor IS supplied.
I made the diagram available for those whom might want to have it to save to ther computers? I have no intentions of putting a cigarrette lighter on my tractor thankyou.
I had hoped I was being helpful?
- JD440ICD2006
I built my own wiring harness based on the diagram in the service manual for the 440IC. I will not put a cig lighter on mine either.
I did add a tach and the key switch.
One good thing is that we can make them the way we like.
- JD440ICD2006
Dang, how could I have forgotten about the radar detectors?
Would you share your wiring diagram with your radar detectors so that I may get mine wired up properly?![Laughing :lol:](./images/smilies/icon_lol.gif)
Radar detectors, something every good crawler should have.
(I just play along when it gets weird)![Wink :wink:](./images/smilies/icon_wink.gif)
BBR Detector
I want a Barely Buried Rock detector. That way, I can steer a little to miss the Barely Buried Rock *before* I get on top of it!
You know, the kind that wind up jarring your teeth when the track goes over them and you vibrate with great amplitude as each and every roller goes over said Barely Buried Rock?
Later!
Also going with the wierd flow here!![Razz :P](./images/smilies/icon_razz.gif)
Later!
- Willyr
LOL grest idea! Up here we dont have rock, we have something that grows in everyones yards called "ledge".
Users browsing this forum: No registered users and 75 guests
