1010c main drive clutch
jma
Post by jma » Fri Aug 06, 2010 2:30 pm
looking for input on drive clutch on 1010c gaser. clutch was stuck. took it apart and there is about 1/8th inch of friction material left should i put the money into it? and what are the measurements of the pressure plate set tool?
Lu47Dan
Post by Lu47Dan » Fri Aug 06, 2010 6:39 pm
If I was that far into the machine it would get a new clutch disc, pressure plate, throw-out bearing, and a pilot bearing. The condition of the surface of the flywheel would determine if I had it faced or not.
Anyway the amount of friction material you have left on the clutch disc sounds really thin to me. Replace the above mentioned parts and have peace of mind that you won't have to do it again anytime soon. :lol:
As to the dimensions of the setting tool I can not help you with that.
Welcome to the sandbox
Dan
1956 420C with GSC blade
jma
Post by jma » Fri Aug 06, 2010 9:36 pm
thanks for the info. the reason I am debating this is I think I am going to put this up for sale once it is back together. I would like a newer bigger machine.
thanks again
Users browsing this forum: No registered users and 265 guests
