350B Engine Removal
350B Engine Removal
Can the engine, radiator, and pump be pulled as a unit?
Also, are there any hidden bolts that will require dropping the belly pan?
Just got the final drives back on and test ran it when all heck broke loose in the flywheel area... Now pulling engine to find what happened... Hoping it's just a clutch...
DavTom-
Here are some threads on the torsional isolator in case you are not familiar with the issue:
http://www.jdcrawlers.com/messageboard/ ... c+isolator
http://www.jdcrawlers.com/messageboard/ ... t=isolator
Thanks Lavoy...
The tech manual isn't very thorough on the engine removal procedure, only dedicated a couple paragraphs to it... But I did find a note that says Alternate method would be to remove the engine, radiator, and pump with support as a unit... So I guess I answered my own question...
Found the flywheel area in it now, with reverser it has an isolator, without reverser it has a clutch... Mine has a reverser so I guess (hope) it's a busted isolater...
The clutch adjustment gauge I purchased from you worked great on the steering clutches...
JWB Contracting
350B Engine Removal
Yes, you can pull the radiator, hydraulic pump and engine as a unit.
You need to remove the hard nose and stump pan. You will need to drain your hydraulic fluid.
I believe there are 6 bolts which hold the engine in, 2 on each side of the engine when looking from the front and 2 from the top of the bell housing side.
Watch out for the reverser cooler lines and power assist on your steering, water temp, oil pressure, tach etc.
Our 350C's have been rewired and we don't reinstall any guards, and leave the front floor boards out. With two men, we have pulled an engine in 37 minutes.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Engine is out...
There's something missing here...
Here are some of the missing pieces...
Pulled the front section of the pan but found out I didn't have to after all...
It's not easy to get a 6'2" 275 pound man under this thing...
There are only 4 bolts holding the engine to the rest of the driveline...
Nope, they are all Deere parts only.
The late style torsonial isolator is obsolete, as is the flywheel you need to do the conversion. Last three isolators I bought from Deere the week they went obsolte were $1500/each.
I have all of the research done and a manufacturer to make the isolators for me, just had not done it due to lack of demand. I know where there are a few flywheels left, so that is not a big deal. If enough people are looking for the late style isolator, I will dig my notes back out and look again at having them made.
The new style listed in that thread is no longer available from JD so looks like I'll be rebuilding this one...KenP wrote:Your cost is going to depend on how you want to fix it.
The spring isolator system is no longer used and there is a replacement system to use in its place.
Try this thread. It contains what you need to know to make a decision:
http://www.jdcrawlers.com/messageboard/ ... php?t=2823
Looks like around $1700 for everything to patch it back up...
A couple of the parts I looked at came with one of the other items so I didn't need them, brought the total down to just under $1500...
1 - AT315819 - ISOLATOR,FLYWHEEL 971.80
1 - JD9449 - BEARING, BALL 8.65
5 - T55320 - RETAINER,SPRING 32.45 each = 162.25
5 - T29675 - SPRING ,ISOLATOR 51.04 each = 255.20
5 - T29706 - ANCHOR ,FLYWHEEL SPRING 11.64 each = 58.20
5 - 25H1052 - PIN, TAPERED AND GROOVED 1.37 each = 6.85
5 - 19H3032 - SCREW, HEX SOCKET HEAD 3.29 each = 16.45
