JD1010 reverser pressures.
Keithfarm1
Post by Keithfarm1 » Fri Jun 23, 2006 11:44 am
Lavoy, Was in wrong port when I talked to you on the phone. That was low pressure port and that reading was normal. When hooked into port to check for 100 to 120 psi found she had 90. Added a shim to the two that were there and brought pressure up to 100. You said you like to run on the high end so now the question is how many shims can be put on valve. Maintenance manual does not say and the parts book says sold in bags of 10 with 9 used so that makes me think maybe three each valve is max.
Thank you, Doug Keith
Keithfarm1
Post by Lavoy » Fri Jun 23, 2006 8:57 pm
Add shims til you get the correct pressure, don't worry about the number of shims.
Users browsing this forum: No registered users and 169 guests
