JD 450-C steering
Flattop
JD 450-C steering
Post by Flattop » Sun Apr 22, 2012 1:45 pm
I recently picked up a John Deere 450-C, dozer. Great old machine. My question is, the right steer lever needs a lot of pulling back most of the time to turn it. The left steer lever is really good. I tightened up the linkage below the seat 2 turns, it helped somewhat. What else could I do :?:
Playing in the dirt is fun.
LeonardL
Post by LeonardL » Sun Apr 22, 2012 5:27 pm
It is probably an adjustment issue. If you will post over in the 350 and newer section you will get more responses and from guys who know more about 450s than I do. But get yourself a good tech manual for your machine and do the adjustments on the linkages. That's where I would start. :D
Flattop
Post by Flattop » Mon Apr 23, 2012 4:57 pm
Thanks for the advice, I just received a manual in the mail today and started reviewing it. I'll check out the 350 messages also. Great machine. I'm starting to change all the fluids and filters next. Thanks again.
