greasing the buttons on the rollers
johnHD
Post by johnHD » Sun May 27, 2012 12:53 pm
i thought about getting a button grease head for my grease gun.
i just went to napa and got regular zerks and installed them instead.
the threads are regular 1/8 npt.
less than 20 bucks problem solved...
john
jdemaris
Post by jdemaris » Sun May 27, 2012 1:08 pm
johnHD wrote:i thought about getting a button grease head for my grease gun.
john
The problem with regular pointed grease fitting on bottom rollers is they get hit with rocks and damaged too easy.
johnHD
Post by johnHD » Sun May 27, 2012 2:02 pm
yes!
and for less than 2 bucks each i fugure they are consumable.
john
Post by JD440ICD2006 » Sun May 27, 2012 3:58 pm
I may missed a point here. Is it the extra cost of button heads over zerks? If so, you will spend a lot of time checking to see when one or more of the zerks have been broken off, and you run the risk of getting dirt inside which will destroy the roller bearings.
Button heads are the only way to go with the bottom rollers. Otherwise, the JD factory would have just used the cheaper zerks.
boler76
zerks vs button heads
Post by boler76 » Sun May 27, 2012 4:40 pm
To eliminate dirt problems if a zerk breaks, use one zerk and install hex head plugs, then use the one zerk and remove the plugs when greasing, takes a little longer and time is money if you are working by the hr, but for hobbyist???
jdemaris
Post by jdemaris » Sun May 27, 2012 4:42 pm
johnHD wrote:yes!
john
I grease my rollers ever time I take my crawler out for a days use. Last thing I want to have to do is jerk around with damaged grease fittings. I don't recall ever have a button-head get smashed so bad it wouldn't take grease. With the pointed zerks - I find enough damaged ones that are up high. I know they'd be nothing but trouble on the bottom rollers.
I can buy new 5/8" X 1/8" pipe button-head fittings for less then $2 each. I.e, an entire new set for 10 rollers is only $20. Not a huge investment. A button-head adapter for grease-gun is $20. Also not a huge investment.
johnHD
Post by johnHD » Tue May 29, 2012 5:18 am
i didn't throw them away. i could put them back on if i needed to work in a pile of rocks.
unlikely at my place since most of it is bottom land.
it would be nice if i could find a set of adaptors as some of my pre 36 harley stuff uses the small ones.
john
Post by JD440ICD2006 » Tue May 29, 2012 5:54 am
johnHD,
I run with the notion that folks can always do what they wish with their machines.
Keep in mind that it does not need to be a rock to break a zerk, it can be anything, sticks, even dirt packed up.
It is your call as to what you wish to do.
johnHD
Post by johnHD » Tue May 29, 2012 7:26 pm
jd,
you are probably correct. i should get the right tool for the job and keep the buttons.
for now i have the rollers greased and that is better than nothing at all!
john
