440 on eBay
robk
440 on eBay
Post by robk » Sat Jan 12, 2013 12:14 pm
2 1010 loaders
1 Massey Ferguson loader backhoe
3 Dodge Power Wagons
1 Wife
3 Kids
shinnery
Post by shinnery » Sat Jan 12, 2013 9:25 pm
Interesting, 4 roller tracks, 4 bolt rails and top rollers.
Post by Lavoy » Sun Jan 13, 2013 7:44 am
If you blow the pic up, you can see the torch marks on the trackframe and rockguard, but took me a while to see it.
robk
Post by robk » Sun Jan 13, 2013 8:35 am
Lavoy, are you talking about the right side shot? I see moisture but darned if I can see "torch marks", professor.
2 1010 loaders
1 Wife
3 Kids
whiteclipse16
Post by whiteclipse16 » Sun Jan 13, 2013 5:01 pm
Man I thought my rails and stuff were bad. That one picture of the front idler makes it look like the pads, rails and everything are shot.
Ben
Post by Lavoy » Sun Jan 13, 2013 5:51 pm
Either side, if you look close you can see where the front roller used to be, and where it looks like 4" or so of the side of the trackframe has been cut off.
JWB Contracting
Clutch housing
Post by JWB Contracting » Sun Jan 13, 2013 6:59 pm
Also notice that the right hand clutch housing has been installed backwards. You would only do this if the frame mounting flange was damaged.
Looks like a parts machine, although not many good parts left.
Lavoy should buy it, raffle it off to a member and then wait for the parts order to come in!!
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
JimAnderson
440 ic
Post by JimAnderson » Sun Jan 13, 2013 8:04 pm
While the steering clutch housing could have been reversed due to
damage it most likely was replaced with JD's last stock of that casting.
Mother Deere tapped holes on both sides so that one part could be
used on either side.Not ideal for the restoration guys but at least you
could get a new one at the dealer.Luck JimAnderson
JWB Contracting
Good to know
Post by JWB Contracting » Sun Jan 13, 2013 8:13 pm
I didn't know that they came with the adjuster hole (barrel bung plug hole) on both sides.
Jason Benesch
JimAnderson
440 ic
Post by JimAnderson » Sun Jan 13, 2013 9:14 pm
You don't see them often.A few years back I bought a 430c that had
one.The 420-430 parts manual shows only one part number for that
casting and if you look closely at the illustration in that manual you
can just make out the second barrel bung.
Shortened track frames,replaced steering clutch housing,busted
front idler and thats just what is visible.That old girl was rode hard
and put up wet many times.Unless someone wants it for parts or
lawn art they better have deep pockets.JMHO! Luck,JimAnderson
Post by Lavoy » Mon Jan 14, 2013 1:08 pm
In later years, the replacement housing was universal, got two on the 440 in the shop right now. All in all, that is what they probably should have done from day one.
shinnery
Post by shinnery » Tue Jan 15, 2013 1:18 am
Well it went to somebody for $1825 plus shipping. They may be a new member for Lavoy soon if not already.
Post by Lavoy » Tue Jan 15, 2013 6:34 pm
Here I thought it was going to your house!
shinnery
Post by shinnery » Tue Jan 15, 2013 7:39 pm
And I have been waiting for your truck to arrive and load up these three 440ICs around here and the 64 blade over in the weeds. That would almost be a truckload I believe. I only have a little over $6K in everything. I sold the extra 2-53 engine I had a couple years ago to one of the members here. My sister keeps hinting at a nursing home but I have too much mess on my 66 acres for her to clean up.
:lol:
Post by Lavoy » Tue Jan 15, 2013 8:26 pm
I'd tell your sister she can go to the nursing home, you have crawlers to work on. :lol:
Users browsing this forum: No registered users and 33 guests
