mc crawler engine racing
Zed
Post by Zed » Thu Jan 17, 2013 7:56 pm
My mc was idling and then a clackety clack developed. within 30 seconds the engine raced uncontrollably.Upon restarting the machine it again raced uncontrollably.The linkage b/n throttle and carburetor seems to function but has no effect on the problem of the engine racing. Any pointers?
Post by jtrichard » Thu Jan 17, 2013 8:04 pm
pull the carb and see if the butterfly fell off of the shaft?...if the linkage is at idle and its running wild its getting fuel and air from some where..... if the linkage is not at idle then you have a governor problem
vtjoe
buterfly gone?
Post by vtjoe » Fri Jan 18, 2013 7:58 am
sounds to me like the noise was the carb butterfly being eaten or maybe just rattling around in the intake- time to pull the carb off for inspection ---
locktite the 2 screws into the shaft with BLUE locktite
1957 420C four roll since 1982
Zed
Post by Zed » Fri Jan 18, 2013 8:45 pm
mc crawler problem solved. screw in carb and butterfly jammed open. evidently one screw doesn't do it.
