JD450B Solenoid
foxd
JD450B Solenoid
Post by foxd » Wed Jan 23, 2013 7:07 am
I have a friend with a 450B crawler. He is looking for a replacement fuel solenoid for his injector pump. AR48219 is the part number and Deere site says it is no longer available. Does anyone know of a good source for this part? Thanks!
'39 B, '48 B, '49 A, '50 B, '54 40U, '55 40U, '59 430U, '60 430C
Post by Tigerhaze » Wed Jan 23, 2013 10:17 am
I think this is what you are referring to if your buddy has a CB pump, but you should confirm as I did not cross reference the part number:
http://www.jdcrawlers.com/messageboard/ ... t=solenoid
Since Lavoy is a Spencer Diesel supplier, I would recommend checking with him first if this is what your buddy needs.
cowboy4996
Post by cowboy4996 » Wed Jan 23, 2013 11:03 am
AR48219 subs to AR90340 for your application..AR90340 subs to 1-RE62240 solenoid $147.09 and says to also order 1-RE37091 kit $12.43. Both parts are available from Deere. Hope this helps.
Users browsing this forum: No registered users and 20 guests
