420 trans reassembly problem
57jd420
Post by 57jd420 » Sat Feb 23, 2013 3:26 pm
so i'm attemping to reassemble my trans on my 420c. the input shaft and power shaft are assembled and in the case. put the pinion shaft in and placed all the gears on according to the servie manual. the pinion shaft will not line up in the to get the bearing on. it seems like the 4th gear driven gear will not clear the 5th speed gear on the input shaft. it has to be something small, i've followed the book to a "T". i'm racking my brain here guys. anybody have any thoughts??
Home of the free because of the BRAVE!!!
1957 420 5 roller 5 speed
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Sat Feb 23, 2013 5:22 pm
The only thing I can think of with out looking at it is that you may have one on backwards. As you slide the pinion shaft in, slide the gears on starting with 2nd and reverse the larger of the two towards the rear of the case then slide the shaft in more just past the cluster gears on the input shaft then install the 1st and 5th gear on with the slot for the shift fork facing the front of the case then slide the shaft a little further and install the 3rd and 4th gear on with the slot for the shift fork facing the rear of the case. That should work. You may want to drop your shifter on and turn the input shaft to see if you can get all the gears to work before you go any further. Good luck
nothing crawles like a deere
57jd420
Post by 57jd420 » Sat Feb 23, 2013 10:34 pm
okay i will try turning the 1st / 5th gear around...the manual shows the shift collar to the rear of the case. the 3rd and 4th gear have a collar that slides between them and its just not alowing the 4th gear to clear the 5th gear on the input shaft. i have the bearing and race in on the power shaft should i take it out until i get all 3 shafts in?? i will take some pics tomorrow if i cant get it figured out.
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Sun Feb 24, 2013 9:39 am
You are right that the 1st and 5th shift collar should be to the rear of the case. I believe that the power shaft should be installed first then the input shaft and the pinion shaft so removing the barring shouldn't be an issue. Before installing the pinion shaft have you checked to se if the PTO engages properly and that the gears on the other shafts are on the shafts in the right sequence?
57jd420
Post by 57jd420 » Sun Feb 24, 2013 8:11 pm
yep pto engages like a dream. the input shaft gears can only go on one way as do the power shaft gears.
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Thu Feb 28, 2013 5:42 pm
Have you found the problem yet?
57jd420
Post by 57jd420 » Sun Mar 03, 2013 11:10 am
so finally got all the gears in the tranny. ripped everything apart and started all over again from scratch. got everything reassembled and had the same problem. removed the bearing and last gear on the input shaft allowing me to lift it up and over about 1" still nothing. i put the castle nut on the pinion shaft so i could rotate the entire assembly back and forth and it just dropped right in. couldnt believe it. :D so if anyone is having issues with a 420 5 speed trans shoot me a message i'm sure i can help since i can reassemble one of these in about 5 min blindfolded. Ha. frustrating for awhile but like the rest of the project gave me alot of opportunity to spend time with my grandpap. now we can really start on putting this crawler back together.
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Sun Mar 03, 2013 12:38 pm
Glad it was something simple.
If you get a chance we would love to see some pictures?
Users browsing this forum: No registered users and 50 guests
