jd450c crawler loader
It crawles backwards when in neutral even when you put in low using clutch &first let out it will crawl backwards then forwards
Re: jd450c crawler loader
Thanks for info, You may be on to something . Can push clutch pedel all the way in ,put HLR in low let out on pedal it will creep backwards . I had the top off tranmission ,clutches looked ok. I could have missed something. Put a new engine clutch in it and had bell housing off should have pulled HLR out then. Hate to take back apart as they are a BEAR to work on. It seems to work ok in reverse.
Bad bearings
My un-educated guess is that the bearings in the HLR are toast.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Well guess i,am going to take in back apart see what I can find. Tried the linkage ajustment . I ,am thinking about getting a 450g dozer are these good dozers.
I hope found the problem broken disk spring ,holds reverse piston in
Users browsing this forum: No registered users and 79 guests
