AZP
Post
by AZP » Sat Mar 16, 2013 6:41 pm
New to the forum, what a great place for info. I dropped the belly pan and can see hydraulic fluid leaking pretty good out of the hole with a loose cotter pin in it while the machine is running. Can someone tell me what is causing the problem, and is it a hard job to repair the problem, i think it is fluid from the reverser? Also will a 2010 repair manual help me to work on the 1010 or do i need a 1010 shop repair manual? Thanks in advance for the help.
Post
by jtrichard » Sat Mar 16, 2013 6:53 pm
get a 1010 book your leak is the input shaft seal most likely...Hate to say it but sounds like its time to pull the engine
AZP
Post
by AZP » Sun Mar 17, 2013 11:20 am
jtrichard, tried to send you a message but am not very good with computer. Thanks for the info on the leak. The guy that loaned me the 2010 book has now found his 1010 book for me to use. Thanks again.AZP
Users browsing this forum: No registered users and 101 guests
