440 icd oil pan
10fords
440 icd oil pan
Post by 10fords » Fri Apr 19, 2013 7:41 am
I took the belly pan off my 440 icd to clean out the years of dirt and rat nests, and after I was finished pressure washing everything it appears that my oil pan is rusted through and leaking! I guess the crud was keeping it plugged for all these years. My question is- what oil pan will fit? Will any detroit diesel 2-53 work, or does it have to be from a 440? Thanks- Scott
shinnery
Post by shinnery » Fri Apr 19, 2013 11:37 pm
The only places JD used the 2-53 Jimmy were the 435 and 440I wheel tractors and the 440ICD crawler. Any of those pans should work, I would think. Need to check with a Detroit Diesel truck engine repair place to see if they have any info on other uses of the 2-53.
If you have the pan off perhaps a welder could flow some brass across your rusted places, or even replace parts of the pan bottom metal.
I really doubt either a 2-71 or 3-53 pan could be made to fit.
10fords
Post by 10fords » Sat Apr 20, 2013 12:01 am
Thanks shinnery. what other applications was the 2-53 used on other than John Deere? And would they have the same oil pan? I'm sure my pan could be repaired, but I would rather get another one if it was readily available.
Post by Lavoy » Sat Apr 20, 2013 11:01 am
2-53 was used in more applications than you can even begin to think of, I would hate to guess how many thousands and thousands of them were built. The main question would be if the Deere pan is the same as the others.
10fords
Post by 10fords » Sun Apr 21, 2013 10:43 am
Lavoy wrote:2-53 was used in more applications than you can even begin to think of, I would hate to guess how many thousands and thousands of them were built. The main question would be if the Deere pan is the same as the others.
That is the million dollar question! Any Ideas on what else used the 2-53 so I can keep my eyes open for a donor? Thanks- Scott
Post by Lavoy » Sun Apr 21, 2013 4:52 pm
Tons of military applications, tons of marine applications, lots of generators, stationary power units. Just type a search into google and see what comes up.
whiteclipse16
Post by whiteclipse16 » Mon Apr 22, 2013 6:43 am
10fords,
Good luck finding a good oil pan. Mine was rusted through in places and I searched and searched for a replacement and didn't have much luck. I'm not sure how many of the other 2-53 applications used the same pan but I know there's a lot of different parts on the JD 2-53.
I ended up just putting a new bottom in mine, maybe one day I'll find an original.
Ben
Post by Lavoy » Mon Apr 22, 2013 9:12 am
You should be able to use the part number from the Deere parts manual I think.
pop pop
Post by pop pop » Mon Apr 22, 2013 10:46 am
since your so close to the coast, ya might look at some boatyard junkpiles,
lotta boats had jimmy's.
me? i would just fab one up using the old one for a skeleton.
10fords
Post by 10fords » Mon Apr 22, 2013 9:43 pm
If I can't find one I will probably have my neighbor who is a fabricator fix it for me. In the meantime I'll keep my eyes open for a replacement.
DukeofDeere
Post by DukeofDeere » Tue Apr 23, 2013 5:46 am
If the pan is just porous sand blast it,
clean it up well and use marine epoxy to give it life again.
I have done this many times with oil pans and gas tanks.
Duke
Users browsing this forum: Google Adsense [Bot] and 189 guests
