1958 Crawler 440ICD Steering Clutch
fordzilla
Post by fordzilla » Wed Aug 28, 2013 12:16 pm
Ok, replaced tensioner, put track back on, got it much tighter than before, used machine for a while, and bam track came off yet again. Any suggestions why this thing keeps coming off?
Post by Lavoy » Wed Aug 28, 2013 2:35 pm
How bad are the pins and bushings?
fordzilla
Post by fordzilla » Wed Aug 28, 2013 3:58 pm
As in the chain part of the track? A couple are really bad, but for the most part, not terribly bad.
Post by Lavoy » Wed Aug 28, 2013 5:37 pm
If one is bad, all are bad, just a couple of yours must be really bad. Measure across 5 pins (4 links) and see what you get for dimension on a taught section of track.
Tight tracks do not necessarily keep a track on. With shot pins and bushings, you are grossly out of pitch, so the track tends to climb the sprocket. A tight track makes this worse.
whiteclipse16
Post by whiteclipse16 » Thu Aug 29, 2013 6:10 am
How bad is your front idler. We got a 1010 with a shot front idler and it throws a track pretty easy.
Ben
gregjo1948
1958 crawler 440icd steering clutch
Post by gregjo1948 » Thu Aug 29, 2013 6:33 am
If you're not turning to the right, the left clutch may be slipping. Put the machine in a situation that causes it to spin the tracks and see if both tracks are actually driving. gregjo1948
fordzilla
Post by fordzilla » Thu Aug 29, 2013 4:33 pm
Both tracks drive, however to that point, the side that keeps throwing tracks is the side that I cant turn to (I think the brake/clutch are shot) It is always under load, but I can't turn that way. (Got this unit about a month ago with the house purchase I made).
gregjo1948
Post by gregjo1948 » Fri Aug 30, 2013 5:59 am
If both tracks are driving and you're not turning to one side, it is probably a stuck(frozen) clutch. This happens frequently when a machine has set idle for a while. You can sometimes free a clutch by bumping something solid. I like using a tree. While holding back the turn lever to the affected side, bump the tree repeatedly and the clutch plates that are stuck together may pop free. Use your common sense when bumping. Don't hit it at high speeds. Good luck, gregjo1948
Users browsing this forum: No registered users and 0 guests
