Finals
Finals
Will the final drive housing interchange between the 440 and the 1010? Thanks gregjo1948
Don't have any info on the 1010 but 440IC up to s/n 456801 use p/n AT17724T (Housing, final drive [T19406T]) and after s/n 456802 use AT17725T (Housing,final drive [T19407T]). If this helps any?
I don't know what is going on but I have been double posting on YT for a couple of weeks now it looks like it is spreading to here also. The edits never double-post for some reason.
Finals
Thanks shinnery--- I can check my 1010 parts manual to see what the part number is for 1010 final and compare. gregjo1948
They are not the same, got one of each on the floor as far as the case itself. Internals are also different for the most part, but externally they look similar.
I am referring to the very late 440 housing in this instance, if you are working on the earlier housing, no comparison at all.
Finals
Thanks Levoy--Looking to maybe pick up a 440 but it has a bad final. Think I better find a final first, before making an offer. gregjo1948
I think I have both early and late final cases on hand.
Finals
Thanks Lavoy-- I don't think I could afford to have them shipped to me in upstate NY. You can shoot me a price and meanwhile I'm searching within a driving distance for a good used one. gregjo1948
Freight on an empty case, I would guess in the $80 range.
Users browsing this forum: No registered users and 0 guests
