40C Idler wheel shaft thread size?
Bret4207
Post by Bret4207 » Mon Oct 21, 2013 6:31 am
Title says it pretty much. Need to chase out the idler wheel shaft threads, need to know the original size. Amazing what 60 years of siting does to threads!
40C, 420C, 1010C-L-BH, Cat D4
Post by Lavoy » Mon Oct 21, 2013 7:21 am
Should be 3/4" NF.
Bret4207
Post by Bret4207 » Mon Oct 21, 2013 9:28 am
Thank you sir!
Bret4207
Post by Bret4207 » Tue Oct 22, 2013 5:20 am
Lavoy, tried it and my shaft is way bigger than 3/4". My largest die is 1" and it was shy by a good bit. I'm thinking 1 1/8" maybe. I'm talking the front idler wheel on a 3 roll.
Post by Lavoy » Tue Oct 22, 2013 8:13 am
Sorry, I assumed 4 or 5 roller. I don't know what thread that is, it is tapered like NPT, so I am not sure it is any sort of standard thread.
Bret4207
Post by Bret4207 » Tue Oct 22, 2013 10:22 am
Okay, thanks anyway!
Post by Lavoy » Tue Oct 22, 2013 12:30 pm
You could try 1" or 1 1/8" NPT, but that is purely a guess, be careful.
Bret4207
Post by Bret4207 » Fri Oct 25, 2013 6:47 am
Just an update- appears they are 1 1/8"-12NF. Gotta beg a loner tap and die someplace to chase threads.
Post by Lavoy » Fri Oct 25, 2013 8:22 am
The threads should have a taper to them.
Post by jtrichard » Fri Oct 25, 2013 4:02 pm
1 1/8" tapered sounds like 3/4" pipe ...3/4" pipe OD is around 1" to 1 1/8"
shinnery
Post by shinnery » Fri Oct 25, 2013 10:37 pm
3/4" NPT shows to have a 1.050 OD. and 14 TPI. At least that is what google tells me. If he runs a 1 1/8-12 tap thru it there will sure be no taper left then.
Bret4207
Post by Bret4207 » Sat Oct 26, 2013 6:32 am
Updated update! 1 1/4"-12, no taper at all. My measurement was off from the galling that occurred taking it apart.
