MC crawler engine block
fictional31m
Post by fictional31m » Thu Oct 31, 2013 8:49 pm
Has any been able to weld a busted block with the ac cast iron welding rods? my mc rod let loose and smacked a crack/hole in the side :(
DukeofDeere
Post by DukeofDeere » Thu Oct 31, 2013 9:32 pm
I have had good success!
Happy welding,
Duke
Post by jtrichard » Thu Oct 31, 2013 10:27 pm
310-16 stainless works good also just do it in short passes 1/2" to 3/4" and let cool before doing more
fictional31m
Post by fictional31m » Fri Nov 01, 2013 11:12 pm
I have only seen this happen on diesel engines but the skirt of the piston is in the pan and the crown is welded inside the bore wrist pin pulled though the piston and of course crashed into the block I dunno if the blow out in the block is repairable[/img]
vtjoe
oops
Post by vtjoe » Sat Nov 02, 2013 6:31 am
all it takes is time and money....plus patience
1957 420C four roll since 1982
DukeofDeere
Post by DukeofDeere » Sat Nov 02, 2013 7:31 am
Did it leak coolant?
The rods I weld with are DC only.
Duke
Post by Lavoy » Sat Nov 02, 2013 8:00 am
Blocks are not hard to come by or that expensive, I probably have one on the shelf.
